Please Help. Need new ECU!
My car has decided to switch on the Engine Warning Light and the ECP light.
I took it in the garage today and they have informed me my car is showing an internal fault on the ECU and it would need to be replaced at a cost of £1600
The part number is 1Z0907115A
Does anyone have any ideas how I could get hold of this cheaper anywhere??
My car is an 07 plate MKII Petrol Vrs
Thanks All
Thanks All
You should contact Shark Performance (Shark90)
I have seen this come up before and I think the ECU can be repaired.
Many thanks I will send a pm.
Just to add further the car is running fine. I have done over 300 miles since the lights have been on. The dealer did mention to me that I have already had the latest update for the ECU
Edited by shane_saintsfc
Just to add. The fault code is..
P0601
Internal Control Module Memory Check Sum Error
Thanks All
Sorry to hear that, Just had the ECU replaced on my 1.8 TFSI after the emmisions light came on - fortunately all done under warranty - though still need to sort out my second key!!
I might try bluefin or shark to see if it overrides the error
Talk to Ben first. He has a section on here or drop him a PM. You could make matters worse by trying to override the error.
Agree with Wardy, talk to someone like Ben first.
I'm sure that the first time you use a bluefin it does a DTC code scan first and if there are any errors, that could be an issue, it won't install.
Still I'd get a through diagnostic opinion first
I think Ben has rescued several members now whos ecu had checksum errors, when the dealer wanted to replace the whole ecu.
Pm Ben (Shark_90) before doing anything.
