Resetting service interval
Hi folks,
I took my car to the garage for a service, and the service indicator's not been reset. (It's a Pre-FL Octavia 2)
It's not a major deal but the beep when I turn on the car's bugging me! ;-)
The garage would reset it for me but it's a faff to take time out. Is there an easy way? (I don't have VAGCOM either before anyone suggests that.)
Thanks in advance. :)
Not if you want to keep it on variable no.
Shame. Ah well, never mind.
What if I don't care about variable servicing? (I'll probably do it early anyway. I just want to stop the beep.)
Then yes you can, do you have maxidot?
No, bog standard manual car, not the DSG/Maxidot.
(By the by, thanks for your help on this.)
1. Ignition off - Press & hold trip reset button.
2. Turn ignition on - wait for 10 seconds.
3. Release trip reset button.
4. Turn ignition off.
I think this is in the manual if you get stuck. As Tech1e says, this will change your servicing from variable to fixed servicing.
Hope this helps.
Thanks all. :)
(Note to self- read manual more carefully! :D )
