Battery Problem
If I leave the car for a couple of days without starting the battery is flat as a pancake.
Not enough juice to open the doors or light the dashboard.
The battery is a new Varta Silver and I fully recharge it on a battery charger when it is flat.
I have measured the charge @ 14-ish volts.
I measured the current use settling around 0.1-0.3amp once all the doors locked, lights turned off etc
The only changes I have made electrically are led sidelights/number plates, headunit and a parrot handsfree.
I dropped the back seats and the bootlight bulb was off and the doorlights are not on.
I am slightly stumped as what to check next, any ideas would be appreciated.
try taking the fuse out from the headunit / parrot etc.
300mA is a lot of current draw, won't take long for that to flatten the battery.
I read a couple of things about the parrot but that is usually because it stays on, mine beeps and turns off (lights go out)
The headunit is a face off so no face no power.
But if one of them has a fault it might be possible, I just didn't want to lose either, but I'm gonna have to do it lol
Edited by Bertee
