Location and Number of Relay supplying ECU power
I believe that I now have the solution to a long-standing engine problem:-
http://www.honestjohn.co.uk/forum/posts/?t=88829
Does any body know where this relay is located and its number ?
I was amazed at the variety of possible causes :-
http://www.locostbuilders.co.uk/forum/8/viewthread.php?tid=84351
http://briskoda.net/forums/topic/136206-engine-dies-while-driving-then-starts-again/page__st__20
Nick
Edited by Clunkclick
I would imagine it is on the bulkhead adjacent to the ECU, if you get someone to turn the ignition on while you listen in the engine bay you should hear the relay click, otherwise it may be behind the RH end plate of the dashboard.
DB.
