Wheel Bolts
As above are Fabia vrs's wheel bolts radius or tapered?
I would put my money on tapered , as radius does tend to be for steelies
Sarah
Anyone confirm?
On my Mk1 Octavia I think they are radius but would have to check later to confirm. I can say, however, they are the same whether used with oem steel wheels or oem alloy wheels, and I would expect the Fabia to be the same.
So if I need tapered what size will I get
Same size, being tapered doesnt change the hub where the bolt goes into.
You may need a different length though, that depends on what wheel your fitting.
