Felicia emissions mot failure
Today my felicia 1.3 failed its mot on the emissions. Recently the car had occasionally felt a bit uneven on acceleration, as if the fuel mix was either a bit rich or lean. This was put down to the lamba sensor which has recently been replaced and the engine has felt very smooth since it was replaced.
The details for the emissions test are:
Fast idle test Fail
Engine Speed 2573 rpm Pass
CO 2.97% Fail
HC 141 ppm Pass
Lamda 0.92 Fail
Second fast idle test Fail
Engine Speed 2576 rpm Pass
CO 3.08 % Fail
HC 142 ppm Pass
Lamda 0.91 Fail
Natural idle test Pass
Engine Speed 782 rpm Pass
CO 0.47 % Pass
Scan shows 2 faults: 00537- Oxygen Sensor Control and 00525- O2 Sensor voltage low. The scanner I have is very basic Autel VAG305.
Hope I haven't missed anything out. Many thanks.
Edited by DISC BRAKES
you normally get the 'sensor voltage low' code when the heater element in the tip of the lambda sensor has gone open circuit, basically the heater element burns out.. sadly there's probably not an aweful lot you can do about it except chucking a new sensor in there... avoid the cheapo ebay ones like the plague.. i got an NGK one from my local motor factors for £50 a few months ago
or if you need to do it on the cheap just swipe one off a scrapper to get in through the mot
Are all the NGK lamda sensors the same model or do they vary?
Would the faulty 02 sensor cause the high CO level on the emissions test?
yes high CO is caused by running rich
edit: the 1.3 and 1.6 both have the same sensor
Edited by TeflonTom
Have ordered NGK lamda sensor to pick up tomorrow.
Lamda sensor fitted. Passed MOT with flying colours.
Thanks for the advice Teflon Tom
glad you got it sorted out :thumbup:
