Gaining Access to MAP Sensor...
I've got the good old 17563 Error on VAG COM, so want to check my sensor/wiring.
Whats the easiest way to get to it on the forge piping?
Arch liner off ?
Headlight out ?
I sense skint knuckles and bleeding hands otherwise :D
Bumper off is easier
Why did you have to say that Sy :rofl:
I'm carp at that kinda thing :giggle:
bumper off and maybe even drivers headlight out :thumbup:
Cheers guys.
Think it's worth just buying a new sensor just incase ? Save me taking the bumper off again if it isnt just the wiring ?
Cheers guys.
hmm could be either or, whats happened is probably the wiring loom wasn't extended when the forge fmic was installed and a core has come loose / snapped.
thats what happened to mine anyways :thumbup:
Would it be fairly obvious ? (remember i'm thick at this kinda stuff)
yes it will be obvious...
4 wires at map sensor... one or more broken / stretched
Water got into mine and corroded the pins. I got a new plug and longer harnes wires which gave me quite a bit of slack. The plug is now encased with a plastic bag and 2 tie wraps
Cheers guys !
Hoping to get a look at it this weekend :)
Will keep you updated :)
