air mass flow meter problems
hi i got a octavia 1.8 vrs mk 1
had problems with air mass flow meter had a diagnostic done
they told me to replace the air mass flow meter, i did but still dont run right.
seems lummpy and hitting a wall when going through the gears
any ideas
thanks
Edited by navyboy
unplug the maf and then go for a drive if its still the same then it wasnt the maf
Does it run any better when warm? (Engine temp sensor needs replacing)
Does the boost fluctuate, i.e. come in and out quickly? (N75 needs replacing)
A general port of call would be the pre-cat sensor as this can cause misreading signals to the MAF and can cause rough/lumpy running.
Steve
Just a thought........
When was the fuel filter last changed??
Steve
