octavia display language
just got a octavia elegance tdi & its great but most of the display is in german & i cant understand it because im scottish so any help will be most welcome
vcds will help !
vcds will help !
cant U do it in Maxidot.
Else use VCDS
When the car is stopped, ignition on you hold the display rocker switch in for more than 1 second. You then use the button underneath the stalk to scroll through the settings available. You want setup which is next to the bottom of the list (don't know what it will be in German) OK if this is working you will get another list Language is the thrird one down. Use the rocker switch to scroll down and the button to select you should find English there -sorry no facility for Scottish
Just play with it untill you get it right !
