Someone please HELP!
Essentially position number 1 has stopped working which isn't exactly a big issue but i find if the fan is off everything steams up and fan position 2 is generally too strong & too noisy to use all the time.
Having checked here I thought it was the resistor pack but speaking to my VW mechanic cousin he seemed to think it would the the controller panel in the dash.
With a new panel running into 3 figures and the resistor being £30 ish I decided to put up with it until something came along.
And come along it did in the for of the SDI being broken via here. I was offered a good price for the controller and the resitor; so was ready to fix the issue. B)
Having followed my Apogee's brilliant guides before to get rid of leave from my fan I removed the glove box and went in hunt of the resistor pack.
What an absolute ******* of a job that is! Now i have small hands but the amount of room to get the resistor out is ridiculous.
Half an hour, some swearing and a lot of removed skin later and the resistor pack was out and replaced.
Keys in, fan on, still no fan position 1. :thumbdown:
A short break to warm up and take on refresfment and read Apogees also brilliant guide on changing the heater control panel.
remove the entire lower dash? Again what a faff but ok.
Trim removed, dash out, old panel removed , new panel put in, ignitinon on fan on, STILL no number 1!!
Now unless by some huge coincidence the panel i bought also has a faulty position 1 I reckon the problem is something else.
Anyone know what??
Faulty switchgear? (assuming that isn't the control panel you speak of)
Indeed it is.
I changed the entire switch/dial pack controller panel this morning and it made no difference :'(
The resistor pack must be ok, generally when they fail you only have a full speed fan and nothing else. When the one in my old mondeo commuter hack failed, it was also accopanied by a nice burning smell through the air vents.
