After some help choosing VCDS
Well i am after VCDS for personal use on my wee lupo gti....
things im after doing...
1. changing the locking procedure so it unlocks on one click of the button (all doors)
2. adding a beep to the locking door procedure
3. scanning faults as my abs light comes on now and again and id like to know what sensor i need to replace
the only computer i have that is mobile is a notebook?
which vcds is for me and any links to all the equipment i will need, looking for something as cheap as possible cheers :thumbup:
If it is only going to be on older cars (pre mk5 golf) you will only need to download vcds lite here: http://www.ross-tech.com/vcds-lite/download/index.html
You will need to buy an activation license and a cheap obd-II dongle from ebay. Or to be safe that it will definately work then a K-II USB dongle from Ross-Techwith a copy of full vcds http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=VCKII&Category_Code=VAGCOM
If you are going to be using it on post 2004 vehicles as well as older cars than http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=VCHUC&Category_Code=IC along with full vcds is what you will have to buy.
its going to be used on an 02 plate lupo GTI
so i only need vcds lite?
then all i do is buy a lead?
and do i need an activation license for vcds lite?
sorry for all the questions but its not simple to understand :thumbup:
Edited by BigJase88
anyone?
anyone?
If that's a model year 2002 with the 7 and 8th digits of the VIN 6E or 6X it does not use CAN bus to communicate to a scan tool.
http://www.ross-tech.net/VCDS/download/VCDSCompatibilityCharts.pdf
The Genuine product would work with our current software and include support is the KII-USB.
Providing that the 3rd party lead works...VCDS-Lite when registered would be fine for that car:
http://www.ross-tech.com/vag-com/vag-functions.html
http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=VCDSLiteReg&Category_Code=VAGCOM
-Dana-
