Gearbox kapooted
18.000 miles rarely abused now making some not nice noises in 4th and 6th and slightly less noise in 2nd.....emoticon-0106-crying.gif
gona have sum1 to ave alook see whats causing it...i'll keep u in mind ta.
ISTR the 6-speed box has two final drives, making 5th and 6th a bit like 3rd and 4th with overdrive. Doesn't explain why 2nd is noisy too, though...
2nd is no where near as bad as 4th an 6th..
Yikes! Its the power i smashed mine at 220bhp
Its all part of the tuning game...Tune it,Break it,Fix it,Repeat :giggle:
It could be the bearing on the end of one of the shafts..
There were 2 types of gearbox, the earlier box, with the metal end to the input shaft is a lot stronger than the later box with the plastic end, we've seen 1 failure in the past with high torque on the gearbox with the plastic end.
Difficult to describe.
Kev
Kev
thats what mine did! i had the later HDS box and it popped the shaft right out the end of it!
was running 220bhp and around 350+lbft torque
Kev
IIRC the metal end has a taper bearing and the platic end they changed it to a cheaper roller bearing, its the roller bearings that collapse and fire them out of the end and that is on the main shaft that carries 6th gear I think.
TBH even on standard cars they do give up from time to time.
That's the one, couldn't remember which shaft it was.. Cheers Ross :thumbup:
Kev
it was fine untill mid morning when all of a sudden its started making some loud rattling noises every time it went in 4th/6th...not as bad in 2nd but in 1st/3rd/5th no probs...
Bit scary. I was always under the impression the gearbox was, to coin a phrase, bullet proof. I guess the older one was?
Definately aint bullet proof what a bang / clunck it goes with when it eventually lets go!!
al have to drive at 10 mph till i can offroad it and remove box :giggle:
