ignition switch change
if i dont manage to get the key in the ignition can anyone advise on how to replace the ignition cylinder /barrel please??
thanks
felicia 1998 1.3mpi
mart
Dropping the steering column to get access to it is dead easy - take off the lower cover then undo the 4 bolts holding it (note the order of the washers and spacers). The awkward part - for obvious reasons - is getting off the two shear bolts that hold the steering lock to the column. Some combination of chisel/drill/violence and a bit of patience should do the job - I know there have been some tips posted here in the past. Then it's just a case of popping the new one on.
many thanks for that
i have done shear bolts in th past. tap em with a punch was how we used to do them
mart
REPLACING IGNITION SWITCH
With Thanks to 'myjalopy'
Didnt do it myself tho..
Oops, but its the barrel you want changed :dull:
Edited by iansmith
a brand new set of the 3 sheer bolts for the steering lock/barrel is about £5 from the skoda dealer FYI
mart
or use easiouts -just get one the right size .
(easiout -hardened steel LH threaded screw -drill hole in bolt, screw in in reverse mode and it SHOULD remove shear bolt)
I've never found shearbolts very tight, and any time I've done it ,I've use a small chisel or old hard screwdriver.
