Felicia Ignition switch connections
hi
i am in the middle of changing the ignition switch on my felicia 1.3mpi 1998
i lost the connections on the switch when i took it out so am unsure as ti the correct connections
i have stripped it out but now i am reconnecting the switch i have used the following connections.
red to 30
white to 16
black to 15
yellow to 50
p nothing connected
having tried the electrics with the steering wheel still out i find that all is working ok but i have no wipers or washers. fuse seems ok (fuse 2 i think)
is there any reason the wipers wouldnt work with the wheel out . am i missing something!
thanks
marty
any ideas greatefully receioved
Edited by isambardbrunel
Having the wheel off should only affect the horn and driver's airbag (if fitted). I'd check the stalk connector and the earthing point near the steering column - if the horn won't work either it's almost certainly a bad earth here.
yhe steering column is partially out. i didnt realise the column had an earth so maybe that is it thanks
mart
mart
now have no headlights. no heater fan ,and lights on buzzer on with doors open but lights off so something is wrong
mart
The blower motor and sidelight switch also earth to point 5 (near the column) - I think it's becoming clear where the issue is ;). For the warning buzzer, you've probably switched on the rear foglight switch - post-facelift models with the buzzer in the instrument cluster do this even if the sidelights are off.
thanks for thoights on this. i do think io have wired the ignition switch wrongly as well as i have had the wipers working now when i changed the connections on the switch.
i have rechecked the earths and all ok.dont forget this all started when i changed the switch. it was ok until then. thanks anyway
marty
i wopuld stilllike to know the correct wiring for the switch as i doint know which termionmals to use
red to 30
white to 16
black to 15
yellow to 50
p nothing connected
these are definitely the correct terminal/colour assignments for the ignition switch
trying checking that the x-contact relay is firmly seated in the fusebox
many thanks
still trying!!
on mine i have two wires the same colour but there is a black wire that can be uncliped try that one to black
