pasenger Electric window
i have a 2005 fabia vrs the pasenger side Electric window will only go up and down using the drivers side switch but not with the pasengers side switch i have tried changing the switch for a new one and looked a the fuses they are fine but still only the drivers side switch will make it work any ideas please?
Hi
Had the very same problem as you. I replaced the window switch still that did not work so out of shear frustration I sat in the the drivers seat and used the drivers side switch to wind the window down the up and when the window was in the up position holding the switch in the up position for a few seconds until I heard a click. I did this five or six times and then tried the the passenger side window switch and it is now working.!!!!!!.
ive had ago at this and still no joy any other ideas p.s. thanks for the reply mate :thumbup:
My passenger side window is similar. The driver side switch works fine, on the passenger switch it only goes up, not down (I think, might be the other way around). It's an 04 Fabia vRS.
