ESP and ABS lights
Hello there, i have recently become the owner of an 06 fabia vrs and after having a couple of days trouble free motoring I got the esp and abs lights appearing on my dash board. When i turned the engine off and back on they went off briefly then came on again after about 5 minutes, i have noticed a post for this happening with the esp light but not both. At the same time there seem to be a juddering feedback through the brake pedal and slight clunking noise from the front end, could this be bushes and pads needed?
Any help on solutions would be greatly appreciated
tia Simon
Edited by sie_gt4
Try use 6 I think it is on the battery box, I had the same and turned out to be hairline crack, 40A weird looking flat metal fuse (frying pan shaped each end) there was a spare 50A fuse on position 4, I stuck it on 6 to see if it worked and it did, £2.50 from dealer
thank you for the quick reply i will give it a try and post up the results :)
tried the fuse in engine (whiched happened to be number 4 on mine) version 1 as per the manual and had no luck.
Any more ideas?? thanks
Without a code scan you'll be stumbling about in the dark!
had the scan done today looked like a front drivers side faulty abs sensor, fingers crossed will be sorted this time tomorrow, cheers
