Dash lights
Does anyone know if it is possible to disable the low windscreen washer light/beep, brake pad warning light and the bulb gone warning lights on the Fabia vRS dash.
I am currently fitting it in a non vrs without the above features.
Yep, details on vagcom site.
Had a quick look, can you point me closer?
Whats it under on the Vag Com website?
Yes it is, if you cant find the info im in work tomorrow and i'll look up the coding numbers for you.
Some info here assuming the fabia clocks use the same codes as most other VAG cars. Ross will be able to clarify for you tomorrow.
