engine replacement
Hi ppl. I have a fabia sedan 2001 1397cc with an engine code AME (55KW) and I was thinking of replacing the engine to a 1.4 16V AUB/BBZ (74KW) since Im not happy with the current performance.
Exactly, what type of changes or what parts need to be changed to complete this engine replacement? I am assuming engine mountings will fit right?
While I can't answer your question - I will warn you that the AUB engines come with issues of their own. Mainly with the piston rings failing. The later BBZ one's are ok I think, so aim for one of those if possible.
You would need at least
Engine
Gearbox
Ecu
Wiring loom
Driveshafts
Dash cluster and keys unless defeating immobiliser in the ecu
Gear shift cables
Clutch slave and pipework
Probably much easier to sell your car and buy a car with that engine . . .
