Oil Filter Cover
Alright folks,
Went to do an oil change on my friends Y reg 1.9 pd100 today, took all my usual vRS oil change kit.
One problem, the socket I use to remove my filter housing cover didn't fit over the nut on his....by about 3mm!
That stumped us for a bit, but got there in the end...
Anyone else been caught out by this?
Any reason for different sizes (other than the obvious 0.5p saving in plastic)?
Cheers,
PL
probably has a different oil filter or just changed the cap because its a 100 not a 130
I think the filter is the same, just a smaller nut. oh well, I guess cost-engineering is the answer!
32 or 36mm are the two possibilities.
A while ago I checked our 2003 (53) 1.9TDI Fabia and it was 36mm.
They changed it in 2004, so up to 2003 (53) it is 36mm (1" 7/16)
From 2004 (04) onwards it is 32mm (1" 1/4)
See also this thread : Oil Change Advice
Edited by Jim H
Ah, that would make sense then! Certainly flummoxed me for a minute, ended up with a trip to halfords but added time to oil change - was late to the pub for the footie!
Cheers for the info folks
PL
