Ecu Pinout
I'm in the process of rewiring my map sensor to try and eliminate an annoying intermittent fault. Only issue is, on the ECU plugs there are a few wires the same colour as the MAP sensor ones. Was just wondering if anyone has a pinout diagram for the ecu?
Cheers!
ECU (81-pin connector) -> Intake Manifold Pressure/Temp Sensor (4-pin connector)
52 -> 1 (brown/blue)
73 -> 2 (blue/yellow)
31 -> 3 (lilac/red)
71 -> 4 (black/yellow)
Don't recall the plug being that big! My ECU has two plugs, does this refer to both of them? Also where does the pin count start? Cheers for your help.
Iirc one is an 81 pin the other is 60.
The connectors are numbered when opened up
