Question for those with non standard suspension..
...do you get interesting groans and creaks from your suspension when going over bumps at low speed, especially if you are not straight on to the bump, ie. turning into a road that has a bump, so you hit it at an angle other than 90 degrees? Mine sometimes makes all sorts of noises, I was wondering whether something is wrong? I've done a couple of thousand miles now over a few months with this suspension so I would have thought that it would have had chance to 'bed in'. I've got eibach vRS springs and Koni adjustable shocks.
Any thoughts?
I used to get the odd clonk from the front, since cured with new top mounts.
This was pretty much the symptoms of the dodgy ARB thing with me. Since had a new one fitted, and only get bangs if I deviate into some big bloody pot-hole. :D
