312mm under 16" rims
Do 312mm brakes fit under the standard 16" Fabia wheels??
Sure its been covered lots but search isnt great on here
THANKS
Yep :yes:
Great stuff!!!
no probs - can't seem to locate any pics at the mo.
It does look like a bit of a tight fit, but they deffo work - awesome brakes and sooo much better than the standard 288mm setup
I searched "312mm brakes standard wheels" and was lots of answers
Matt
They deffo fit under standard wheels, they did on my old Ibiza FR wheels :)
Thanks Guys, dont want to be changing the wheels just yet you see
Hopefully going to see if I can get new disc, pads, hoses and calipers tomorrow then just leaves me to find some second hand carriers
Ad Lav... Are you the same one as of seatcupra.net??
Matt
http://briskoda.net/forums/index.php?app=core&module=search&do=search&fromMainBar=1
I must be doing something wrong then :?
Edit that doesn't bring up what I see... When i search for what you quoted i get "No matches found for..."
Forget all of that^^ Just seen my search bar tool is set to "this topic" so only searching this topic... Just put it to "This forum" and im sorted
Edited by st3f4n
Don't look like it and says standard fit on S3, 5x112 S3 aren't 312mm.
ok... Hopefully should get bosch disc and pads with mine for about that price if im lucky
Calipers, carriers, discs and pads for £150? That is a bargain.
:thumbup: Tis are bargain, most of the time the used kit goes for that kinda dolla
Matt
Matt
Indeed...kicking myself now! :o
There you go...
Fills the rim well I'd say!
£150 is a pretty good deal, I got mine for £100 incl discs n' pads. They were used though.
Edited by farmer11
£150 will be the 1st bid...
Yes, same one from SCN - I have a Fabia vRS now hence why i'm on here more :)
