dump valve fitment
has anyone attempted to fit a bailey dump valve to the octavia rs? easy or not? :confused:
Easy....for a dv30 you just connect up the same way as for standard dv.
You'll need a L shape connecotr for the top...should come as standard... and replace the connectors with jubilee clips.
or if its the dv26 twin piston... then connect to the black pipe and plug up hole on the air intake pipe!
as above - and it'll make your car sound like Darth Vader :p
ive fitted the dump valve took bout an hour coz i wasnt to sure how to do it but now whoooooooooosh!!!! sounds fantastic, just the pager alarm to go now.
