will 8x17 et30 fit a fabia vrs
i've been looking in to getting some new wheels for my fabia and have fell in love with the rotiform nue wheels but have no idea if these will fit the fabia. there 8x17" and have a et30 which i think is alot for the fabia considering the fabia is et38.
currently on standard suspension but will be changing to coilover setup soon.
et30 should look awesome on a 8J wheel :thumbup:
thanks so you think they'd fit then? what tyre size for these?
have asked g-werks and awesome-gti but had no reply back
yeah they will fit no problem whatsover....
as long as stud pattern is 5x100 and the centre bore matches....
i'd run either 205/40/17 or 215/40/17... will give a nice stretched look :thumbup:
yeah they are 5x100 thanks
On coulovers if you go real low
There is a bit off a problem make sure you fold that lip of the arch in maybe roll the front arch a bit
I have et 33 that was a problem 205/40 tire Don’t go for 215
Edited by --GT--
Or just ask te owner of this one
super nice wheels :thumbup:
have tried to ask g-werks for advise but have had nothing back and i'm a bit scared of running those tyres 185/35r17
and an et 20 offset
Your right that’s dangerous and 195/40 ?
I ran 9 inch porsche twists on the rear at et 25 with 205/40/17's on coilovers and had no rubbing issues
Granted that was on decent kw coilovers and a sensible drop
I cant see any issues at 8 inch with et30 and 205/40/17 tires tbh
heres mine as low as it would go on the back (adjusters out)
bearing in mind i was at et25... 5mm closer to the arch than your going to be
and i had 9 inch wheels wearing 205/40/17 rubber
and i cant recall it rubbing?
The front ones give problems not on the rear
Ok these are et 33 205-40 and whit the lip not folded they destroy my tires
Now still some rubbing on the arch liner noting to bad
Edited by --GT--
if you raised it 10mm you'd still retain 90% looks but the car will be far more drivable and won't destroy tires....
tbh you can't have eveything, wide wheels and low stance, something has got to give...
push came to shove rolling the front arches wont be the end of the world :thumbup:
but i think a sensible height would got a long way...
on the front with the porsche twists i ran 205/40/17 7.5J at ET20 and it was fine at a sensible drop :thumbup:
thanks for the comments, when i ran 18" on my pug 306 i found that the side wall on the falken 452 tyre gave me more clearance on my arches than any other tyre so i'll will be going for these aswell every little helps.
what drops are you two running?
Erm i think i had the back without adjusters just the cups in place on kw v1 coils front to match
Maybe -60mm
