clutch advise
Ok guys. I think my clutch on way out. I got mk2 octy 1.9 tdi its done over 100000 n clutch feels to be slippin. Wot wud u all recomend to fit n wot r rough prices.
Hope u can help.
See the post from Mike Holroyd about his conversion to a Single Mass Flywheel.
At 100K you will need to replace flywheel and clutch, no point just putting a new clutch on to a 100K Dual Mass Flywheel as you can almost guarantee the flywheel will fail at some point, especially with the new clutch on there.
Much cheaper to go the SMF route and then no worries about flywheel failure going forward.
Forgot to ask, where are you in the UK? I know a garage in the Chesterfield area that will do a DMF Flywheel and clutch for about £750 using genuine VAG parts.
Edited by andyvee
Been lookin into smf ones. Some recomend em some don't. And I'm in leeds area so chesterfield not to far away. Which garage is it I got fairly good knowledge round there ??
PMd you details
Not sure if he will do a SMF, but they have done plenty of DMFs in Audi's VW and Skoda diesels.
Go for the single system its only £250 I had mine done 85,000 miles ago
If its a taxi you can get around 50% off fitting from a main dealer but ask first
Edited by skippy41
