Window gremlin
Morning,
My rear offside window has developed a problem. When the ignition is switched off the window goes down all the way of it's own accord!
The switch in the drivers door will raise it if i push down (opposite to what it should) not up?
The actual door controls no longer do anything.
Is this electrical or a problem with the actuator?
Tris
Water in the connector block to the window motor in the drivers door I would suspect. Pop off the drivers door trim and check the connector block for signs of water on the connector pins.
Thanks for the reply, when you say door trim do you mean the whole door card or the black plastic trim with the window switches in it?
if so how do i take this off?
Tris
