Hola folks!
Hi guys!
I've just bought myself an '01 Octavia Elegance TDi and thought I'd sign up for the site, as I'll be looking to change a few things about it and any tips and advice would be much appreciated.
The stereo is dire.
Replace it at the earliest opportunity :D
The stereo is dire.
Hello and Welcome:D
:iagree:
then get a Jabba re-map,improve the whole driving experience!!! :thumbup:
and give you a even bigger smile :D
Alright guys.
An Alpine CDA-9831R is on it's way, I'll probably be putting in my old Alpine 12-Disc too when I get chance ;)
Already fitted the Dragon Performance tuning box too, I'm just tweaking the setting now.
Alright guys.
An Alpine CDA-9831R is on it's way' date=' I'll probably be putting in my old Alpine 12-Disc too when I get chance ;)
[/quote']
A wise plan.
It's pretty easy to make up a bracket to fit a different changer to the standard mounting points like the pictures here.
http://www.briskoda.net/forums/t3090-all-in-place---pictures.html
Cheers, that's one of the things I was going to be asking about in time! There's not a huge rush, I can make do with the single slot on the new HU.
I've had my old Alpine HU so long it's got a tape slot instead, otherwise I would have fitted by now.
I just used a couple of flat metal T-pieces as sold in Wilkinsons for under a quid.
Drilled two holes in each for the screws on the sony changer , then a single larger hole for the bolt where the OEM changer attached and that holds them in place very firmly
