Headlight adjustment Fab Vrs
After getting her back from some warranty work(inc H'light adjustment!!)
they are now too low!!! Not wanting to snap anything I thought I'd ask!!
Is it anything to do with the two white plastic hex adjustery type things on top of the light assy? :o
Answers on a postcard,and thanks
I take it you have standard headlight not Xenons?
If so then they can be simply adjusted on the white hex/phiilips screws.
Answers on a postcard' date='and thanks[/quote']
Full beam or dips? The white plastic hex adjusters on a xenon car adjust main beam height...
Brilliant thanks guys, standard halogens fitted.
Don't you have the option in the vRS to electrically operate the headlight beam from a roller switch inside the car? I have that in mine, and my lights are halogens.
Yep these are standard, but I think they're designed to be used only when the back of the car is loaded, eg during towing, so you can lower the beam and not dazzle oncoming traffic. Position 0 is the standard unloaded position should be the highest position for the beam and I think Mac is just asking about how to get this a bit higher :D Hope that's clearer than it sounds when I read it back to myself :rofl:
Chris
:rofl:
Perhaps we need a negative setting so we can blind those who feel fog lights are required during a clear-visibility situation :D :D :D
Perhaps we need a negative setting so we can blind those who feel knob lights are required during a clear-visibility situation :D :D :D
:iagree: :rofl:
