Does the 2008 L&K occy Estate 2.0PD have a roll bar
Just a quick question as I am not sure but does anyone know if the 2008 L&K Occy Estate 2.0PD have a roll bar?
I am thinking after reading through of maybe improving the handling and lowering the car a bit. I have read that eibach springs / Anti Lift Kit / Rear Anti Roll Bar is a good upgrade?
Yea every car has a front and rear anti roll bar and it's then a compromise on performance and comfort which is determined by the thickness/strength of the bar (along with other suspension parts) e.g. Vrs anti roll bar will be stronger than the one fitted to your car and the eibach is more again. Yea the mods you have listed above will transform the cars handling (I would see what peoples response is on the springs on standard dampers as most change both). The rear anti roll bar is usually changed alone as front is a much bigger job to replace and good results from it.
Just remember if u drop and stiffen the car then will be less comfortable but will handle better, it's the matter of getting the best compromise. Good luck
