Front ARB
What front ARB are you guys running? I'm not sure what the previous owner fitted but it's red and doesn't look very sturdy but I'm not sure if it's worth spunking out money to replace it. :wonder:
Is there an accepted best front ARB?
Also what's considered better out of the Whiteline and Jabba rear ARB's?
ARB's are funny mate. I'm bot speaking from experience on the furby but I've got adjustable arbs front and rear on my Nissan and the front one is best at it's softest setting.
I've tried having it on harder all this does is make the front end "feel" tight and more responsive but it increased under steer and did no allow enough weight transfer in the corners to get good grip.
Also just looking at a bar tells you nothing about it's stiffness. Some hollow bars are big but weak compaired to some solid stiff versions.
For RARB, there was a debate which is better. Result steered towards Jabba if you can afford it. Was only a few weeks ago so shouldn't be too hard to find it.
Sent from my Desire HD using Tapatalk
You don't really want a stiff front bar. Will increase understeer.
