engine light interpretation
Ive got an engine warning light on and want to work out what the problem is...
Where abouts is the diagnostic port on a Mk1 Octavia, and what sort of setup do I need?
This is a bit of a new area to me so talk slowly pls :yes:
Under the steering wheel there's a shelf, there's a plastic cover that you unclip revealing the diagnostic port.
As for code readers it depends on how much you want to spend and there's a big range depending on price
To sort out an engine management issue, once ive identified and replaced/sorted the sensor etc that was giving a dodgy outpput, do the warning lights go out automatically? Or do I need to reset something in the software with a diagnostic device?
Id prefer to try and keep the costs down as much as possible
you may need to reset, you can do this by taking the battery off though.
