DMF and clutch
I've a 2008 Rs Common rail tdi and I've to replace the dual mass flywheel and clutch. Can you tell me it the PD RS clutch and flywheel the same as the common rail RS tdi? The engine code is CEGA. Hope you can help
don't think they are, but someone with access to part numbers will confirm. Probably worth trying to locate a SMF instead - drop Mike Holroyd a PM as he got a SMF for a 1.9 and can point you in the direction of a supplier / manufacturer.
I've had a look on ETOS and it looks like the clutch is the same for the PD & CR engines. But the DMF is different.
Graham
Edited by Big Gray
Helix Make a SMF for PD170 Not sure bout CR170
Ah crap, just ordered a luk dm one :(
