JOM coilies, rear springs falling out?
When my rear coilies were fitted last week a noticed the spring and adjuster are separate to the shock! I have taken the rear adjusters out but when I jack the car up now rear springs seem very loose almost as if they would fall out of i went over a bump, is this normal?
keep the rear adjuster in place... only removed the threaded adjuster part, the bottom part (cup) helps hold the springs in place :thumbup:
But the standards didn't have anything on they just sat there
They'll not fall out over a bump, unless your going so fast the whole back of your car lifts up.
I think someone else who was worried put a cable tie round to keep it in place when jacking it up etc.
Matt
Exactly the standard springs were longer so have tension to hold them in place
I seeeeeeeeeee thanks you sir
