Fabia Fault Code Help
Hi, can anyone help me out by explaining these fault codes from VAGCOM in laymans terms:
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-00 - Open or Short to Plus
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
31-10 - Open or Short to Ground - Intermittent
Many thanks.
The interior sensors for the alarm are disconnected?
The motor that controls the recirculation flap for the heater is faulty?
The air conditioning system has a leak or needs regassing.
The ignition has been turned on with the high pressure sensor disconnected, the sensor has since been reconnected but the code is now downgraded to intermittent.
