Octavia 2007 electric windows
Hi, I have a Skoda Octavia 2007 model and my front electric windows do not work at all. Is there a main fuse for the windows and where is it located? Any ideas on why they are not working would be appreciated. Thanks
First thing to try would be the fuse; location should be listed in the handbook-sorry, I'm at work so can't check right now. The fact that both aren't working makes the fuse most likely as the first place to look.
HTH.
Checked every fuse inside and in engine compartment and they are ok, any other ideas would be great, thanks
You may need to find a member with VCDS\VagCom to scan the car for you and see what shows up-look in the VCDS section for someone near you?
