Open window
When driving at 50mph plus I seem to get the same noise as u get when driving with your windows open from behind the dash.
I've had a look and can't seem to find anything that will make this noise,it's weird as I can hear it so clearly
Check the grommets which the wires go through, also your pollen filter just incase. Are the carpets wet?
I haven't noticed the carpets being wet.
Will the grommits be behind the bulk head(engine side) behind the heat shield?
I know theres some under the scuttle panel, not sure about anymore
some windscreen wipers can cause a noise too, plus the plastic that runs down the side of the screen - is it secure?
