high clutch pedal
Hi all, the bite on the clutch pedal of my 97 felicia 1.3mpi is rather high, the clutch doesn't slip and the gearbox is as easy to use as ever. Was wondering if there is anyway the bite point can be adjusted or am i going to have to stump up for a new clutch? thanks in advance :wonder:
adjusting the cable won't do anything in this case, it will just make the clutch slip... time to stump up for a new clutch i'm afraid, although it's not too bad a job to do tbh so if you are handy wit the the spanners it might save you a few notes
