Spacers
Hi everyone
I had some 15mm Eibach hubcentric spacers fitted on my '56 Seat Ibiza Cupra and took them off before I sold it and bought my Octavia vRS MK2. My question is, will they fit on the Octavia ok, or do I need to order some specific ones for my model. The spacers I have from the Ibiza are Eibach Pro-spacer S90-2-15-005. The 15mm ones specifically for the Octavia are S90-2-15-013. I'm assuming the wheels might not actually fit onto the spacers possibly?
Many thanks in advance, Matt
they may be the wrong PCD i.e. the holes will be in the wrong place for the bolts to go through, do you know what the PCD on the ibiza was? the vRS is 5 X 112 HTH
Hi mate, thanks for quick response! :)
The Ibiza was 5x100 if I remember correctly, so i'm guessing it's a no go. I'll buy some new ones.
Many thanks, Matt
Not sure about the Eibach ones, but some spacers have two different sets of holes predrilled, to fit 5x100 and 5x112?
If yours have 10 holes, this is probably the case.
I've just checked them and they have 10 holes in them. Is it worth me putting them on seeing if they fit ok?
Regards, Matt
Regards, Matt
Check Eibach's website-they may be 5x100 and 5x108?
IIRC mine were 5x110 & 5x112?
Ok thanks for the reply :)
I'll go check now
Regards, Matt
I've just downloaded the PDF file from the Eibach website and it says they're 5x100/112. I quickly did some rough measurements on the bolt circle itself on the spacers and they seem to match up too, so I'm gonna give them a go tomorrow. Thanks for your help guys :)
Regards, Matt
will be a good result then :thumbup: *fingers crossed*
just hold the spacer behing the spare wheel be easier than taking the wheel off to see if they fit
Edited by Dallan
Ah good idea :yes: I'll give it a go this aft.
