Felicia 1.9 air bag light
My air bag light is permanently on i have had some one have a look it and there is no problems but im just wondering if any one knows how i can turn it off :S
you need to clear the fault codes from the abs module using diagnostics equipment, this will turn off the light, assuming there are no actual faults with the system it should stay off.. it's quite common for people to inadvertently switch on the ignition when they've remove the steering wheel/slip ring or whatever which automatically brings on the light because it thinks the ignitor has gone open circuit, the light will show whenever there are any fault codes stored in the abs module and wont turn off automatically when the problem has been rectified
