Gear Oil Change
I have a MK2 Octy 1.9 TDI on a 57 plate. Although the gear oil spec by Skoda is ‘filled for life’ there are several blogs suggesting a change will prolong the gearbox life and have in the past always changed gear oil on a regular basis to good effect.
The latest spec oil is G070, needs 1.9 ltrs. also at about £8 a ltr from a dealer its cheap. I’ve noticed that it’s not the usual gear oil that I’ve used in the past but much thinner, more like ATF oil without the red colour. I assume more common thicker 75w gear oil will effect the gear change and mpg.
Now before I start it seems that VW in their infinite wisdom have on some cars have moved the engine and gearbox (tilting it forward) such that the filler hole isn’t at the correct level, the filling method for those boxes is described in one of VW’s tech buletins. Does anyone know if the Octavia fill hole is at the correct level? I suspect it is reading some of the blogs on this forum.
If you like me are in doubt I will measure what comes out and make sure the same amount of new oil goes back even if that means I have to remove the air box etc as per VW Buletin to refill the correct amount.
Edited by silver73
