Rear washer
Hi me again another small problem I have I the rear washer works but there seems to be no pressure there when I take the end cap of the wiper it squirts behind me but when on it just squirts inside the cap the pipe does keep popping off in the engine bay anyone had the same issue or know a solution
Seized jet assembly inside rear wiper motor assembly, there is a repair kit available from Skoda.
Thanks I'll look into that
About £5.50. Take care when you remove the part. It's very fragile and needs to be gently turned whilst pulling it out.
Thanks for that info I rang skoda in mk to see if the had they supposed to ring me back but didn't that have really bad service and I'll make it known to lol
Skoda Aylesbury, Hughes (the Merc dealer) were pretty good when I used them. Might be worth seeing if they'll post it out if MK are being idiots? Also found VW MK to be quite bad, yet the Aylesbury branch is brilliant IME.
Kl thank I'll give them a call see what they say
