door card stained
theres been a leak on the rear drivers side passenger door at some point and the door card fabric has slight staining to it anyone have any suggestions for removing it? dont have a steamer so if any tips without using one of those id be most grateful
The rear doors are held on with screw behind the grab handle, a screw beind the opening handle, screws along the bottom and clips around the edge.
Easy to remove.
The Fabia doors are a weak point for leaking due to the seal on the carrier panel failing. The approved method is to apply sealer from about half way up the edge one side, along the bottom and half way up the other side. Working it in to the gap.
If when you remove the panel and are not met face to face with sealer, the door will at some point in the future will leak again. Sorry.
Hope this helps.
Edited by VandrosdisTech
