just fitted intake to standard furby.
just fitted my cupra intake to my standard (at the moment) furby. virdict, deffinatly alot smother and seams to pull better in all gears. good buy me thinks!!
Good to hear... although could it not be a placebo effect? Not having a go, just geniunely wondering...
maybe? then again maybe not? its defo smoother.
What was the mileage before you got it done? No other changes made I take it?
Had mine on for about 4k now and it's smoother for sure, added bonus is when you come to have a re-map done it will help even more :D
Mikejay how does the pipe fit with the scoop part?
saw you picking this up today mike. was it easy to fit? i think it will be my first mod on my new ibiza.
Tom.
simple to fit mate!! and you dont need to remove your maf sensor to get to that screw! remove the plastic flap in the air scoop to it makes a hell of a difference!!!
I dont think when it's standard it does too much, maybe a bit of grunt lower down but nothing OTT (and your mpg suffers a bit), get it remapped and it'll be worth 10 bhp & 7 lb/ft of torque however as I believe they can sustain a higher boost of 1.6 bar? :D
mpg has not suffered 1 bit!! it feels alot smoother and does pull better now i have removed the plastic bit from my scoop.
indeed thats what mine seems to be holding
No, your wrong MPG is unchanged
Have to agree there is absolutly no change in MPG whatsoever with the Seat pipe.
Maybe you floored it more when you fitted it, but my driving has remained the same and my MPG has also remained the same.
when i went pickin the intake up from warrington i was doing around 50 mpg, put intake on reset my trip conputor and did same journy (about 12 miles) same speeds etc and got exactly the same, 50 mpg!!
I found in standard form it actually made the MPG better.
