Windscreen Teardrop Wipe
I'm trying to disable the Windscreen Teardrop Wipe using VCDS, but can't find the option anywhere. I've managed all the other tweaks I wanted, auto door locking etc but can only find a teardrop function for the rear screen. Am I being a biff and have missed it?!
Try looking in adaptation rather than coding in Central electric [09]!
Or if your car is older (pre FL) Central convenience [46]!
Thanks for your reply Mike.
I'll plug it in again tonight and have a good play I think. Mine is pre FL, so I'll have a good dig about in 46. I'm sure I've just skipped past it by accident.
Woody
I have enabled Tear Drop on the rear wiper of my FL Estate, when should it do its thing? I have front tear drop off with the auto wipers. :thumbup:
I'm guessing the rear would tear wipe after using the washer, like the fronts
  • 2 months later...
Went looking for this earlier too, as the teardrop wipe on the front annoys me. Most of the time it's not necessary, and if I find it is, I'll flick the wiper down myself!
Could only find the option to turn the function on for the rear wiper; nothing for the fronts.
Anyone?
There should be a sub controller on 09 "central electrics". The refers to RLS (rain/light sensor) even if you don't have one I think you can access it and front tear drop is in there.
HTH
BTW- I'm referring to an FL but I believe it's in same place on pre.
BIG Nick :)
Cheers. Did some looking around last night and what I saw did seem to suggest there was a slave controller attached to 09.
Will check later.
Steve.
VCDS > Select > 09 - Central Electronics > Coding - 07 > Select Subsystem/Slave #1 (WWS) which is Wiper Module. There you can disable the Teardrop Wiping.
Thank-you :)
