octavia 4x4
recently bought 2003 1.8t 4x4 octavia with 72k and fsh well looked after
just noticed its started making a whining/whirring above 25/30 mph at front end
stops when i sharply flick wheel left and right so does this eliminate worn wheel bearing.
tyres are michelens on original alloys and have decent tread
noise gets louder as the speed increases
dipping clutch or coasting doesnt change
thought id got a cracking reliable car !
only thing i can think of is maybe a drive shaft,if so anyone know cost replacement
if anyone could spread me some light i would really appreciate it
Does sound more wheel/hub related TBH
Worth checking the brakes too for binding/rubbing
When I've had driveshafts go, I've felt distinct slippage. They also tend to get rapidily worse.
had new pad set just b4 got car.
im gonna get out and check though
cheers for you views S/M
Dose the whining/whirring come back right away??? if its dose then it may indeed be bearings.
If drive shafts cheack your oil levels on F and R as thay could be very low and you yanking it form side to side could be moving whats left of the oil about and making it better for a bit.
yes the noise comes back immediately
so it seems it could be bearings then, ill take a look in morning.
just thought bearings normally fail on cornering when under load
Have had them do the groning even when driving strate but this was from a one failing from hitting a put hole :-)
