Sticking throttle problem
I picked up my VRS this week, and I've noticed that sometimes as I come off the throttle and put it into Neutral/depress the clutch, the throttle seems to be sticking slightly as the idle will be slightly higher than usual, if I then press/lift the throttle from underneath it goes back to normal idle.
Any ideas please as to how it can be fixed?
I do have warrenty if it's a problem that needs to be looked at properly.
Liam
Hi I would put my money on the pedal being at fault new ones are around the £70-£80 I believe, apparently an easy job but as it's under warranty personally I would take it back to the garage
It's not the pedal but apparently the 'fly by wire' throttle control module.
The module will cost you around £80
Sorry wasn't sure on what it was called so just put pedal lol either way I'd still take it back to the garage being under warranty an all
ok cheers guys I'll see what Skoda say, it's under warrenty with them.
