Fault 01317 Control Module in Instrument Cluster (J285)
Hello,
I need advise please
I think I posted somewhere else, wrong in the forum, this question so I will repeat the problem:
I am new here, and glad to be a member.
I would like an advise from a Tech specialist.
ABS and ASR itself and the light on board not functining.
Tested with vag com and
"1 Fault Found: 01317 - Control Module in Instrument Cluster (J285)
000 - "
Nothing elese. Tested with laptop the ABS ASR and other and works fine. Remade the link between the main socket behind the main board (the one with the watces), checked the fuses all OK, and still not working.
What coul be the solution ? Changing the module would cost very much.
I have a Skoda Octavia 2 1,9 TDI 105 from 2008, warranty expired two months ago
Please advise
Thank you
Anyone? please
