Superb camera
Has someone instaled this
http://cgi.ebay.co.u...=item33623ab808
And can enyone post pictures how it looks like?Is this good?
Please reply.
It sticks out lick a sore thumb. so I postioned mine under the bumper.
My link
Presumably you need the multimedia adaptor for the camera as well as the PS2?
My link
Hey tnx for pictures,but i need to know some things,and if you can help me i would be very gratefull.
Which adapter you use to connect navigation and camera?Where goes wires from camera to navi?And very important question is:can camera work,when you drive a car(or works some when you are in reverse)?Is there one adapter which could connect ipod and camera and sony ps2?Or if you can post e-bay links of adapters you use(or staff you need to make it work all of these things)
Thank you very much!
Edited by MilanM
My link
Thank you for this great piece of work mate, really nice job. I wish u would put this as a guide or 'How to' in the Superb Technical Guide section. :)
  • 4 months later...
i installed mine in one of the holes for the reverse sensors (which was broken anyway) I used a composite video to RGB conerter with 2 inputs so I could plug in my MP3 player. All worked fine till I had the locks changed by my local Skoda dealer (DM Keith, Bradford) after the keys were stolen from my house. They denied it was anything to do with what they had done. I used the 'Vid on' pin on the 9 pin connector fed from a switched 12v signal via a 4.7K resistor so the display is forced to the camera when reverse is selected. I have checked all the wiring and still can't find out what is wrong. Anyone have any ideas ??
Note: The camera etc still work fine it's just the switching to reverse camera when I select reverse which doesn't. BTW I also fitted a switch for manual override (with another resistor and diode) which does work but only when the DX unit is set to Aux input, so basically it is the Vid on function which seems to not work any more.
Edited by skodasuperb
