Should I Get A New Wheel Aligment After Loweringsprings?
When fitting lowering springs in the front it should increase chamber.. wouldnt it?
So do I really need a wheel aligment (spelling?) ?
If anyone knows, whats the original aligment setup? toe-in, caster, chamber dive and so on .. for the RS?
How much more chamber do you think I should have ?
For faster turnin and more grip on trackdays and so on...
Don't know original settings... or optimum settings.... but I guess getting an alignment done would be a good idea. Dont know where you are based but if you are near Micheldever i would recommend going there - you can tell them what sort of setup you are after and they can make the adjustments for you there and then :)
Mattias,
Yes you should get it checked. I have the settings at home (they are from the dealer workshop manual). I can put the numbers up tonight if you want.
Jon
The camber is fixed so you can't do anyting about it.
/ Christian
/ Christian
Are you sure?
Yes
Getting a full wheel alignment check carried out could be cheaper than finding out from tyre wear that the alignment is wrong.
Originally posted by TaviaRS in this post
Yes
oh ok then ;)
Originally posted by DaveU in this post
Are you sure?
Absolutely :)
I was wrong its caster that can't be adjusted :rolleyes: serves me right for going from memory.
Just going to put copies of the workshop data sheets in another thread.
BEWARE THEY WILL NOT BE DIAL UP FRIENDLY!
Absolutely :)
Still? ;)
Still? ;)
Yes! I mean No! Yes... I don't know.:D
yup - mkIV platform is fixed
probably thrown out the tracking good & proper though - bed the springs in for a week & get the alignment done.
/me hugs his 10mm bolts in 11mm holes on the MK2 Ibiza/Cordoba
