Air Box to Manifold Pipe in Silicone
I bet this has been asked a million times but does the above exist for a VRS?
Does anyone make one or is it possible to make your own?
The MAF is in the way. Though if you're after relocating the lot, I think you'll have to design the configuration yourself. Closest mods to what you're asking I've seen are those running custom air boxes, BMC CDA(?) or similar.
Obvious question... Why do you want to remove it?
EDIT: There isn't an air-box to manifold pipe. There's an airbox to turbo pipe, is that what you're after?
J.
Edited by vindaloo
Ok i meant maf to manifold
How can there be an airbox to turbo pipe? Or is that what i'm on about?!
The pipe that's attached to the maf via the plastic current pipe is the TIP.
( turbo intake pipe)
Why bother replacing it?
same reason you would replace any pipe with silcone: improved stenght and reliability, reduced friction and drag and improved cosmetics
Is the TIP SFS part number THS223?
